Why don't the Tranny fit???
Old Jan 26, 2004 | 08:03 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
OK heres the deal....
I pulled my block out cause basically i had nothing to do(first time on my camaro). my friend had a performane clutch he gave to me for pretty cheap so i decided to put it on. when i go to put the block back in, the tranny wont go completely into the block. the bellhousing is about 1/2 inch from the block. did i not push the pilot bushing in far enough or something. im pretty sure i installed the clutch disc the right way. advice, please, before i rent the cherrypicker again.
thx in advance...
CAM
Old Jan 26, 2004 | 08:26 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you should pull the trans from the bellhousing and install the bellhousing first.
Old Jan 27, 2004 | 05:06 AM
ede's Avatar
ede
yeah most people normally pull the trans to r&r the clutch. try drawing the bell up to the block with the bolts. if it's 1/2" away from the block it's on the dowells.
Old Jan 27, 2004 | 08:10 AM
Meatikis's Avatar
Car: '86 Z-28
thx
Old Jan 27, 2004 | 08:33 AM
Meatikis's Avatar
Car: '86 Z-28
there are only two bolts hold the tranny to the bellhousing, correct? i can't remember...
Old Jan 27, 2004 | 11:37 AM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
no, theres 4 15 or 16mm bolts on the 4 corners of the tranny, and theres 6 or 7 15 mm bolts that hold the BH to the block...
gta90
Sep 15, 2015 04:00 PM
89lsc
Aug 14, 2015 04:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
