Swapping in LT1 heads and intake
Old Jan 26, 2004 | 08:31 PM
Chris90Formula's Avatar
I'm already set on swapping an LT1 intake to replace the tpi on the 350 I'm installing. Since the motor is out car my original plan was to port out the stock iron heads and modifying the LT1 intake. But now I'm thinking about getting a set of LT1 heads and modifying them to work with my setup. I've seen a couple of other members have attempted this before. Are these the basic steps that are involved:
1. block off large coolant passages on the underside of the head and drill steam holes.
2. Run coolant lines from the front of head to the radiator.
3. Run crossover tube on rear of heads? or can these openings just be blocked off?
4. For the intake the only mods would be to mount the distributer, block off egr, and adapt fuel lines.
Am I missing anything? I'm on a tight budget, but I think that I can get the LT1 heads and intake for about $350. What are your opinions?
Thanks,
Chris
Old Jan 26, 2004 | 09:48 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am going to have the same thing done as soon as I get the LT1 heads from my friends car. They will be going on my 305 Formula.
Are you going to modify them yourself or have a machine shop do it? If a shop is going to do it, can you let us know what they charge.
Old Jan 26, 2004 | 10:31 PM
85TransAm406's Avatar
Car: 1985 Trans Am
2&3, you dont need a crossover or anything, you just have to run lines from the front or rear coolant outlets in the heads to a remote thermostat housing, not the radiator. The front or rear remaining ports can be blocked off.
Old Jan 27, 2004 | 05:45 AM
I'm going to do most of the modifications myself. I have a friend that can weld the aluminum plugs for me. I might have to take them to a shop to get cut.
Yes, running the coolant lines from the heads to the remote thermostat makes sense.
Why did the factory LT1's use the a crossover tube?
Old Jan 27, 2004 | 06:24 AM
I have another question. How will I route the coolant lines to the remote thermostat without interfering with accessory brackets? Since brackets are usually flush to the head, I'm assuming that they would cover the exit for the coolant lines.
Old Jan 27, 2004 | 07:52 AM
Car: 1985 Trans Am
run the lines from the back of the heads to the remote thermostat housing, possibly mounted on the driver's side inner fender by the radiator inlet.
One coolant crossover seems to work for the small block chevy, i don't see why you can't run the LT1 heads without a crossover tube.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
