alt bracket?diffrence?
Old Jan 26, 2004 | 11:13 PM
icebird_1981's Avatar
sup people just spent an hour looken on the net for a nice chrome altinator bracket. i found some but i was wondering if there is any diffrence? i got a 70s 350 block and wondering is there diffrent size brackets?i found one for real cheap but it says its for a chevy 350ci engine with a long water pump.....long water pump? would this work on my engine?
i dont wanna order something and not fit no what i mean.
any info on these brackets would be great.
thanks
Old Jan 27, 2004 | 05:49 AM
ede's Avatar
ede
if it's for a long water pump and you have a long water pump it'd work
Old Jan 28, 2004 | 06:47 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
I beg to differ. Not all pre 85 long waterpump brakets work with all 350's. for example I went through 3 brackets before I got one that worked. Somehow my alternator was too big for the bracket or something. Just make sure they have a good return policy.
Old Jan 28, 2004 | 07:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The alternators are the same, up until they changed to the other side of the car. The internally-regulated ones are even the same dimensions as the old ones with the external regulator (71-back or thereabouts).
The older brackets bolted to a stud that was on the water outlet, instead of a bolt being there. The newer ones bolt to a specific boss on the front of the manifold; that boss is about an inch in front of and about a half inch below and to the right of the water outlet bolt. Get the right bracket and put it in the right place, it'll work right; with stock intakes anyway, or at least intakes that have the water outlet in the exact stock location.
Some very early long water pumps also had the boss for the bottom of that bracket about 3/4" rearward of the later ones. SO sometimes you need a spacer between the bolt hole on the bracket, and the bolt hole boss on the water pump.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
