Cheap set of heads to work over
Old Jan 28, 2004 | 12:37 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
as a project for the automotive technology class we are required to rebuild a set of heads.. I'm looking for something fairly in expensive to start with... my school will provide anything nessicary to rebuild them.. hopefully i can talk em into some aftermarket parts.. anyway what is a good casting i would be able to aquire fairly cheap at a local boneyard?
Old Jan 28, 2004 | 12:41 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
I hear 416's are really good stockers if you can find a set.
Old Jan 28, 2004 | 01:26 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
081s and 601s are also very good to work with. Port and polish them before doing the valve job, though. Will work great on a 305 or a 350.
Old Jan 28, 2004 | 09:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have a set of 416's I'm willing to give to a worthy cause. Last I checked, shipping would be about $35/head.
I suspect they need guides. I don't know what shape the valves are in, but there were no apparent leaks at the seats. Replacing the springs would be a very good idea.
Go whole-hog: 1.94" intake valves, porting work - they'd be great performance heads.
Old Jan 28, 2004 | 11:30 AM
89RsPower!'s Avatar
What we are required to do is strip em down to nothin glass beed, check for warpage/cracks, add larger valves if we wanted, full port and polish, 3 angle valve job and flow test em after we're finished.. at the vary least i will pin the studs but if I can get my school to pay screw in studs machining the heads for them would be my prefered option...I also plan on gasket matching em as well... anything else you guys can think of while I'm at it? the heads will eventually make their way onto a 350... I Know new valve springs are a must but until I actually put them into service I may just reuse the old springs to complete the project then after decideing what cam will be used with these heads decided on a good set of springs at a later time... 57 check pm... would really appreciate it bro.. what ever the easiest/cheapest way for you would be fine...best of all I know just the place to ask questions and post updated photos of my work for suggestions and help
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
