GMTech,Vader, all COOLING FAN GURUS help..
Old Jan 21, 2001 | 10:53 AM
rondubbs's Avatar
my fans wont come on, i put back the stock fan switch, the fuse is good, replaced and checked relays. jumped the fans and they turned on so the motors are good,, unplugged the fan switch and grounded it and 1 relay ticked. put in a new coolant temp sensor.
my question is what are all the components that make the fans turn on, or in my case not turn on????
1988 GTA Trans Am 350tpi: 44k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, flux capasitor
Old Jan 21, 2001 | 11:26 AM
Vader's Avatar
Ron,
Possibly the fusible link for the fans. Check the schematic. It's for a single fan, but is similar:
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 22, 2001 | 08:49 AM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I would suspect the fusible link. Also check the connections at the relay. Grab, pull, and wiggle the "big" wires at the relay while it's engergized.
'87 IROC 5.7l TPI - original owner!
Old Jan 24, 2001 | 10:20 PM
rondubbs's Avatar
what and where is the fusible link and how do i test it??
sorry but im bad with wiring
Old Jan 26, 2001 | 07:42 PM
rondubbs's Avatar
Old Jan 26, 2001 | 07:50 PM
Vader's Avatar
Ron,
I'm not sure on your '87, but my '86 TA has the fusible links near the battery and positive power node mounted on the inner fender near the battery. The fusible links are a smaller gauge of wire installed in the power distribution wiring. They are usually easy to find since there ae large black rubber insulated crimp connectors along the wire where the links begin and end. Look for a big slug of rubber molded around a power wire.
Later,
Vader
KaleCo Auto Parts
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
