Engine Drives at WOT again!!
Old Jan 26, 2001 | 02:19 PM
84TransAm's Avatar
Here's whats up.
Driving home from a friends house and accelerate kinda quick, then go to shift, and the RPM is begged @ redline. CRAP! I'm able to kick it down for the time being and go home. Then as i'm going up my street it does it again, and pulls the accelerator pedal with it. What could be the problem? Also, when the (stock) air cleaner is in place, the 2 main barrels (the things @ the top) are cracked open when it sits in place. Took a bottle of silicone lube to the connections and did this a bit. Last time it happened i took it to a mechanic and they did this somewhere on the carb and it seemed to fix it. What could be a cause of this? I need a permanent fix.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
RPO codes point to Recaro version
Daily Driver, Flowmaster 80 Series
Old Jan 26, 2001 | 04:01 PM
Blade's Avatar
The throtle shaft on the carb might be bent or the bushings might be waaaay worn. The linkage has a lot crap on it making it stick... I'd say go have a look. Move the gas pedal cable yourself and see what makes it stick. Also while u're at it get a can of carb cleaner, spray it on the linkage and clean everythign really good, then spray some WD40 on it
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 26, 2001 | 07:56 PM
84TransAm's Avatar
Thanks Blade:
I sprayed the silicone lube this afternoon, didn't do anything 4 me. Coming home from work (before i read your post) I leaned over and pulled the acellerator back by hand (in my dark & quiet neighborhood w/ wide streets) and the RPM went down. So something is making the accellerator cable stick. The spring connecting that stuff to the carb looks worn, so it's gonna be replaced 1st. Car is fine as long as i don't romp on it.
--Steve S--
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
