Internally Balanced Flexplate 383
Old Jan 28, 2004 | 12:17 PM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
Anyone know if the 86 & up 153t flexplates for small BC/1 piece main, internally balanced would use a weight?
I just received my new one from jegs and it has a weight. I thought an internally balanced engine didn't use one.
Old Jan 28, 2004 | 12:26 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Yes, it will have a weight on it. My B&M one did.
Old Jan 28, 2004 | 01:10 PM
ede's Avatar
ede
one piece cranks seal parts even though it's internally balanced there is a weight on the flex palte to make up for the mass removed when the flywheel flange was removed to allow for the one piece crank seal. it confuses a lot of people and is listed wrong or in a confussing way in lot of catalogs
Old Jan 29, 2004 | 09:50 AM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
I was told it was internally balanced on the front and externally balanced on the rear of the one piece cranks. Is this accurate?
Old Jan 29, 2004 | 09:58 AM
ede's Avatar
ede
not really. the balance of an engine is determined by the mass of the couter weights compared to the mass of the rod piston assembly. equall mass would be an internal balance engine, which a 350 and 305 is. the weight on the fly wheel is to replace the mass removed from the flywheel flange
Old Jan 29, 2004 | 03:26 PM
Car: YTG Camaro
Engine: 383
Great information I love this place!
This would explain why I had a hard time finding one to begin with. I knew it shouldn't have been a problem. I must have had 4 other guy's I know scratching their head.
Thanks, The project will continue, look out spring stang's.
LT1Formula
Oct 8, 2015 08:34 PM
mfp189
Sep 27, 2015 09:25 AM
