ZZ4 or L98?
Old Jan 29, 2004 | 12:08 PM
stupid4901's Avatar
ZZ4 or L98?
I'm swapping out the 305 for a 350 this summer and want to start to get the parts togethor ASAP. I'm gonna be running nitrous, like 200-300 eventually in smaller bursts (can't think of what its called), so I want a forged crank and a 4-bolt block. It also has to be 86-up compatible. I'm not gonna bore or stroke it for now, so what would be the better route to take?
Old Jan 29, 2004 | 01:52 PM
ULTM8Z's Avatar
The ZZ4 is definitely a more stout platform to build your engine. Though, the L98 heads have the pre-1987 intake bolt flange. You'll need a Corvette or aftermarket base, or modify a post-1987 Camaro base.
The ZZ4 has the following components:
Forged crank
Powder metal LT4 connecting rods
Hypereutectic pistons
Vortec style block
Pretty good stuff...
Old Jan 29, 2004 | 02:06 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
yeah but a l98 less$$$$
more $$$$ to spend somewere else and a rebuilt l98 is 3year warranty zz4 no warranty if you leave it stock wit nos!
Old Jan 29, 2004 | 02:10 PM
FOX-GTA_89's Avatar
ultim8z
verry nice ride and what the f*** is your big pulley at the place
of the ac??? run your strap rootine like light truck 1989 use the binder to pull with a v groove instead to push!
Old Jan 29, 2004 | 02:14 PM
stupid4901's Avatar
So the zz4 is compatible with my Q-Jet stuff? If I want to run nitrous will I have to replace those hypereutics for forged? Are there decently priced 350 short blocks with all forged internals and 87-up compatible? I don't have a serpentine set-up if that answers any questions about the AC pulley.
Old Jan 29, 2004 | 02:21 PM
FOX-GTA_89's Avatar
hyperreutectic piston.
when you rebuilt a block its cheeper to put forged piston than the stock hyperreutectic...for a 96lt1 it was the case...and the thing about the belt had annything to doo with the conversation.
i saw the picture of ultima8z and i say that sorry
and i dont know if hyperreutectic would resist to lot of nos
Old Jan 29, 2004 | 02:27 PM
ULTM8Z's Avatar
Yeah, hyper. pistons probably wouldn't hold up to 300 hp in nitrous add-on. You'd probably be better off building an engine yourself.
quote by FOX-GTA_89:
"verry nice ride and what the f*** is your big pulley at the place
of the ac??? run your strap rootine like light truck 1989 use the binder to pull with a v groove instead to push"
Thanks.... I think. Not sure what you mean about binder? I don't mind the non-AC idler pulley that I'm running now. It has no resistance and it's a factory piece- so it's fine with me.
Old Jan 29, 2004 | 03:52 PM
stupid4901's Avatar
What would be a good block to get? I'm guessing a 350 TPI block from thirdgens, right?
Old Jan 29, 2004 | 03:54 PM
ULTM8Z's Avatar
I'd look at getting a four-bolt main block. The third gens are two bolt I believe. ZZ4 blocks are four-bolt mains and have provisions for late model roller cams. The best of both worlds.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
