Piston question; please read
Old Jan 30, 2004 | 12:44 PM
irocfreak's Avatar
Car: 1986 Iroc-z
Engine: Soon to be 350
Transmission: 700junk4
What kind of piston pins do i need to use for my 91 l98 roller motor connecting rods
Old Jan 30, 2004 | 05:22 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What ever kind you want, for a 350 with 5.7" rods.
Old Jan 30, 2004 | 05:27 PM
ede's Avatar
ede
a better answer would be pins to match the pistons you're using plus a set of rods preped for the pins
Old Jan 31, 2004 | 12:27 AM
irocfreak's Avatar
Car: 1986 Iroc-z
so what kind of pins are used with stock rods
Old Jan 31, 2004 | 01:13 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Press fit.
The small end of the rod is heated, then the piston is set over it. Next the pin is pushed through.
Once the small end cools, it shrinks back onto the pin.
Old Jan 31, 2004 | 06:11 AM
ede's Avatar
ede
it sounds like you don't really know what to ask or understand wrist pins. the pins match the piston. from the factory gm uses pressed pins. you can use pressed or floating pins with factory rods. you need to bush the rod and add an oil feed hole for floating pins. the pins match the piston. rods can work with either.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
