Serpentine setup question
Old Jan 30, 2004 | 10:12 PM
PonchoTA's Avatar
Was there any year that the V8's had a serpentine belt drive, but not the reverse-driven water pump? Without resorting to an expensive March-type system, that is.
I would love to retrofit my older car with the serpentine belt, but do not want to deal with fabrication and modification to make a water pump go the wrong way.
Or, is there a way to modify one to work?
Thanks!
Old Jan 30, 2004 | 10:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
why would you convert to serp. setup and not spend the $50 to buy a reverse rotation water pump???
and all serp setups to my knowledge changed to that reverse pump.
Old Jan 30, 2004 | 10:56 PM
PonchoTA's Avatar
It's not a matter of spending the extra for the pump, it's the difference in cooling method.
From what I understand, if you are not using the reverse flow heads (LT1 type) it's not wise to try. The heads and block both are cooled totally differently and I don't think the standard SBC takes too kindly to the difference either.
Thanks for the input!
I was hoping there was maybe one or two years that the serp drive was introduced, and the reverse flow w/p had not been put on yet.
Or maybe someone else had done this conversion and would be willing to share their information.
Old Jan 30, 2004 | 11:36 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The 88-92 cars with serpentine were not reverse cooled, the cooling is the same, the pump just spins the opposite direction of the crank....
Old Jan 31, 2004 | 12:19 AM
xpndbl3's Avatar
Car: 1984 Z28
exactly what i was trying to say. it's not a LT1 style reverse cooling. just reverse rotation pump
Old Jan 31, 2004 | 10:15 AM
PonchoTA's Avatar
Ok, see that's the kind of info I was looking for! I was not aware that there were 2 sets out there!
Thanks for your help! Now I'll be looking for the brackets to bolt on!
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
