where can i get a EGR block off plate?
Jegs, Summit, Autozone, ect..
Most local parts houses carry them in stock.
Wishmaster's87IROC
close
- Join DateFeb 2000
- LocationWinston salem, NC
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car1987 1SICIROC.....1999 TransAm
- Engine385 HSR.....LS1
- Transmission700R4 with Midwest 3400 2.4str...M6
- Axle/GearsSLP Zexel Posi unit 3.42's...3.73's
- Liked:0 Times in 0 Posts
I made mine out of a piece of thin metal. I didnt have a agasket I just used to bottom of the EGR as a template.
does blocking off the egr cause the ecm to throw a trouble code constantly or would leaving the egr sol intact keep this from happening?
Thanks,
~Shotz~
Thanks,
~Shotz~
Quote:
Thanks,
~Shotz~
You will get all kind of codes and the car will run like poo. You need to delete it from your PROM if you are getting rid of it. Most people just get rid of it to clean up their engine bay. It doesn't have any power making potential upon removal. Your gas mileage may just go down a bit but thats it.Originally posted by jloshotz
Thanks,
~Shotz~
that's kinda what i figured, Shifty. I'm gonna leave everything intact with new. Thanks for your reply!
~Shotz~
~Shotz~
br()bert
close
- Join DateNov 2003
- LocationPhilly
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car85 firebird
- EnginePos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
- Transmission700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
You do not get all kinds of codes, you will probably get the egr code but thats it and your car will not run like poo.
I and some of my friends have the egr blocked and dissconnected and do not have the prom burnt.
