Fuel Pump question
Old Jan 31, 2004 | 04:33 PM
Wilburwm's Avatar
Car: 89 T/A
Engine: 305 TBI (Hopefully LS1 someday)
Transmission: 700 R4 (T-56 is planned too)
Fuel Pump question
I just bought the Racetronix L98 F-body GSS340M Fuel Pump Kit and they sent me an e-mail saying: "You will have to make sure you have a regulator and return line that will allow the pressure to be lowered to apx. 15PSI."
I have a 89 Trans Am, 5.0L, TBI preparing for a 2001 LS1 swapp in the next couple of months.
What do they mean by that?
Thanks,
Wayne
Old Feb 1, 2004 | 12:57 PM
Wilburwm's Avatar
Car: 89 T/A
Should this be in the TBI Section?
Old Feb 1, 2004 | 01:28 PM
ede's Avatar
ede
WAG, i'd say they mean you have to have a regulator that allows you to set the fuel preasure below 15 psi. if you have a tbi pump it may not be much of a problem but it the pump is fro tpi it would be for a much higher preasure.
Old Feb 3, 2004 | 04:40 PM
Wilburwm's Avatar
Car: 89 T/A
wow, I can't seem to fond any, under $150. Lol, I figured it would be cheap. Anyone know where I can get a cheap one? I don't think I'll need it with the LS1, right?
Old Feb 3, 2004 | 07:07 PM
littlebagz's Avatar
Car: 89 Z28
Engine: 350 with ads
Barry Grant carriesd one in summit, Check the online catatlog. It is an adjustable regulator with bypass. I have my TPI pump feeding a Holley 600 with no problem. I run 7lbs at idle with teh stock TPI pump....
Old Feb 3, 2004 | 07:18 PM
Wilburwm's Avatar
Car: 89 T/A
Is the stock TBI Fuel pressure regulator not good enough that I need to have another? Cause the stock TBI pump is less than $40, although I'd hate to have to do it twice, lol. Cause I'm sure 9 to 13 PSI is not gonna be enought for the LS1.
Old Feb 3, 2004 | 10:14 PM
Wilburwm's Avatar
Car: 89 T/A
I found what I need to run the Racetronix pump:
http://www.top-downsolutions.com/pr...c7938c736d01632
but I'm gonna wait and see how much more I can get out of the existing pump, should have the money to start the swapp in March, hopefully.
Thanks guys,
Wayne
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
