No start prob. Im stumped
Old Jan 31, 2004 | 09:27 PM
Blue91''s Avatar
The car is a 95 Olds with a 3.8 V6. Ive got spark, fuel to the cylinders,compression and no codes. Ive checked all the obvious things , at least anything I can think of. Ive done a search on it allready and there are only a few posts that have all the similar symptoms. It is an OBD-2 car so there arent timing adjustments or anything that I am aware of to get out of adjustment. It dosent even sputter like a car out of time.Its not an F- body but it is your typical GM MAF type MPFI system.
-Can a bad MAF sensor cause a no start condition?
-The car seemed like it flooded from cranking and cranking so I cleaned and re-gaped plugs and blew out the cylinders, still will not start.
-I pulled the plugs and checked them, they fire when cranking the engine with the wire installed on it while the plug touches a ground.
Im stumped! Anyone have any ideas as to what could be the problem??
Old Feb 1, 2004 | 06:39 AM
ede's Avatar
ede
try a new set of plugs, if it flooded that usually trashes the plugs. it should fire with fuel, compression, and spark. might want to check the spark with a spark checker to see if it's strong enough and check fuel preasure to see if it's within specs
BRoss99
Aug 10, 2025 05:08 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
CORV3TT3
Aug 23, 2015 11:26 AM
cstrobel65
Aug 15, 2015 10:19 AM
Elliswon
Aug 10, 2015 12:33 PM
