questions about this camshaft
Old Jan 31, 2004 | 09:29 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
I'm in the process of installing a comp cam and when I pulled the old cam out of the block, I figured it was the stock camshaft but now I don't think so. Engraved on the end was three sets of numbers, here they go SLP51002
F8202
4714YN
I went to SLP's website and saw where they had two roller camshafts for the TPI cars, but they were numbered 51004 and 51008. Can anyone tell me more about this camshaft?
Old Jan 31, 2004 | 10:35 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
check out speed-pro,i believe that is an aftermarket cam from them.
Old Jan 31, 2004 | 10:38 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
SLP Cams
51002 206/214 .470/.490 .501/.522 112deg
51006 214/224 .470/.490 .501/.522 115deg 92 Firehawk
51010 224/232 .490/.510 .522/.544 112deg
taken from http://www.geocities.com/MotorCity/7610/cams.htm
Old Feb 1, 2004 | 01:54 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Rusty is correct, those are the specs for the SLP 51002. The reason its not on their site anymore is because its discontinued. Its an ok cam, not much bigger than a stock L98 cam... just has alot more lift.
Old Feb 1, 2004 | 05:07 AM
pigsticker's Avatar
Car: 1992 z28
Thanks guys, I knew someone on here could help me out.
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
