Manual Fuel Pump Change/Upgrade
Old Jan 27, 2001 | 08:53 PM
gruveb's Avatar
Car: 1989 IROC-1
My fuel pump is fried. I have an 84 Z 28 with the L69.
Are there any pointers on changing the mechanical fuel pump?
Old Jan 27, 2001 | 09:09 PM
snakeskinner's Avatar
the toughest part, if you havn't changed one, is keeping the drive rod up while you install the new one. there is a large rod that goes through the block and rides on the cam eccentric to push the arm on the pump up and down. this wants to slide out as you install the new one. Everyone has a different trick to hold it up. Some use a thick grease to prevent it from sliding, I prefer to use a thin, bendable, metal ruler I have to hold the rod up and once you slide the pump arm underneath it, you can slide the ruler out. best thing to do is get into the situation and then figure out a way that works for you. have fun.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old Jan 28, 2001 | 11:59 AM
Vader's Avatar
Gruv,
The last time I changed a mechanical fuel pump, I used a longer bolt threded into the front accessory mounting hole to gently hold the push rod in place while installing the new pump.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 28, 2001 | 04:37 PM
yeah that does work depending on the block because the bolt isn't through on some blocks.
Kyle Osterholt
Okarche, Oklahoma
86 T/A 383 TPI
80 T/A Pace Car
73 Opel GT
73 bronco
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
