where and what is an h o coil
Old Jan 28, 2001 | 09:28 PM
85F-body's Avatar
i just wanted to know cause i got some new 8mm wires for my camaro also do i even have an h o coil i have a 85 i roc z28 and i also want to get a new distributor cap
Old Jan 28, 2001 | 10:10 PM
Vader's Avatar
85,
That would probably be a "high output" ignition coil. If you have the stock coil, you probably don't have one. If you have an '85, it really doesn't matter since you have the coil in the distributor cap, hence, no coil wire.
Packard Electric makes some nice 8mm silicone wires for your engine.
Later,
Vader
"Make Me Bad..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 28, 2001 | 11:27 PM
85F-body's Avatar
so if i replace the whole distributor cap then i won't have to replace the h o coil and how much are caps usally?
Old Jan 28, 2001 | 11:44 PM
burnoutrpm's Avatar
caps are about 10-20 $ and theyre redily avaliable and you dont have a high output (hot) coil from the fcatory.
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 and a 600 edlebrock manual choke.
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Giocio
Oct 1, 2015 12:20 PM
