3 Vortec Head Questions
Old Jan 29, 2001 | 02:01 PM
Mike86Z28's Avatar
Car: 98 Z28
1. Could I use them on a stock 79 Truck 350 motor, from what I remember they had dished pistons, I heard the vortecs only work with flat-top pistons.
2. Will regular headers bolt up to the Vortecs or do I need special headers?
3. What kind of springs would I need to run if I run a Xtreme Energy 274H cam?
Old Jan 29, 2001 | 02:16 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
1. Vortec heads have a 64cc combustion chamber. The only reason to I could think of not to use a dished piston would be too low a compression ratio...this would all depend how how dished the pistons were.
2. Vortec heads have the standard exhaust pattern, so regular headers will work.
3. I'm no spring expert...Comp Cams has a spring they reccommend using with every cam they make. Check thier website.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jan 29, 2001 | 02:31 PM
Mike86Z28's Avatar
Car: 98 Z28
1. I am talking about the stock pistons, I belive they are dished, and the compression is 8.5:1 w/ the stock heads (think they are 76cc heads), so what would be a rough est. of the compression w/ vortecs?
Oh and would stock pushrods work or would I need to get longer ones? Centerbolt valve covers too right?
[This message has been edited by Mike86Z28 (edited January 29, 2001).]
Old Jan 29, 2001 | 03:37 PM
Mark305TBI's Avatar
Compression should be right around 10:1.
Yes, centerbolt valve covers are needed.
Not sure on the pushrods...I would guess that the stock length would work, can somebody confirm?
-Mark W.
Old Jan 29, 2001 | 04:24 PM
Mike86Z28's Avatar
Car: 98 Z28
Man, 10:1 with iron heads is kinda pushing it, I guess I could use a thick head gasket but the highest octane gas around here is 93, and that is only at a few stores, not to abundant.
Old Jan 29, 2001 | 06:44 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I have a very similar setup to the one youre after....my cam is the "biggest" one you can use.....compression will be ok on 93 octane gas as long as you dont get carried away with advance. stock pushrods will work fine.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
