Unusual engine clatter
Old Jan 28, 2001 | 10:33 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Recently when the engine is under load (cold) it has the clicking noise (kinda like detonation), yet everything checks out ok, new spark plugs cap, rotor, wires. I don't know if the 89 LO3's have a knock sensor. But one the engine is hot the knocking goes away. But If I shut the engine off for a couple of minutes, the knocking is back for a while. I'm getting no error codes, everything on the engine is stock. And the timing is right on. Any ideas? the car is in storage right now, but I'm thinking of looking at the o2 sensor.. I've read quite a few things relating to this sensor.. Thanks
89 RS Camaro, 305 TBI
Currently All Stock
Old Jan 28, 2001 | 11:10 PM
berlinetta84's Avatar
almost sounds like a hydraulic lifter. you said it was when it was under load, well does it do it when it is at a cold idle? i dont think lifters change much depending on the load, so if its clicking when its under load but not at idle, then it may be a misfire.
Old Jan 28, 2001 | 11:24 PM
burnoutrpm's Avatar
yes you have a knock sensor !
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 and a 600 edlebrock manual choke.
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Jan 29, 2001 | 07:52 AM
Car: 89 Camaro RS
Engine: 305 TBI
Reply 1: no at a cold idle it fine, if it's a miss fire, I wonder where the problem could be.. since it's had a full tune up..
Reply 2: It does have one.. where is it? I couldn't locate it, I even taped on the block to try and simulate detonation, and the engine didn't make any adjustments in the timing for it. Thanks
Currently All Stock
Old Jan 29, 2001 | 09:27 AM
Birmass's Avatar
The knock sensor is on the passenger side of the block. It's right along the edge of the oil pan seal.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Jan 29, 2001 | 07:24 PM
Car: 89 Camaro RS
Engine: 305 TBI
Ok, thanks guys.. I'll check for the sensor, and see if it's toast.. it could be detonation. If I have any more problems, I'll post again.. since the car is in storage.
Currently All Stock
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
