general type question
Old Feb 4, 2004 | 11:26 AM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
I have a newly rebuilt 350 done by the best shop in my area. I have a HSR intake on it that I put on and used good silicone gasket maker on all the surfaces that mate with the heads and block. Made extra shure that I got a good seal so there would be no oil leaks. Used good quality intake gaskets also. The engin has 2000 miles on it and ever since I have been running it I get oil seeping from every seal on it. Expcially around the intake . I dot understand why and cant seem to stop it. I have good crank case ventilation so I dont thin its getting a lot of crank case pressure. Oil look clean, dosent seem to get any blowby into crank case. Any body expeianced this before? Thanks
Old Feb 4, 2004 | 11:37 AM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Check the tpi section. There are lots of posts on the stealth ram. Including a few that talk about how there were a couple different manifolds made, and some of them are known to warp.
Old Feb 4, 2004 | 11:42 AM
ede's Avatar
ede
not sure what you used RTV on, but you wouldn't want it on coated gaskets like the intake or head. you'd want liquid tefelon sealer on the intake bolts and head bolts plus all the oil plugs.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
