No Heat
Old Jan 30, 2001 | 07:50 AM
92Z1LE's Avatar
No Heat
In the last couple of days, my heater has quit blowing hot air. It only blows cold. Also, the car is running hot. It almost overheated yesterday. Is it just the thermostat, or something else? Thanks for any help.
92 1LE 25th Anniversary Heritage Package
305 5-speed
Hooker Headers, SLP exhuast, K&N filters
Old Jan 30, 2001 | 11:02 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
You need to check to make sure your coolant passages are free. Check to make sure your thermostat still works properly, pull your heater core out and have blow compressed air in one tube and see if it comes out the other, check your radiator, flush the entire system. Make sure you do it the right way, go out and get one of those flush & fill kits... they're cheap (like $3) and effective. Check to make sure there is no debris on the front of the radiator, that your fans are working properly, and that you have the proper mixture of coolant/water.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Jan 30, 2001 | 12:17 PM
Guest
Guest
Posts: n/a
Make sure you have enough water in the radiator. Thats what it sounds like.
Old Jan 30, 2001 | 01:16 PM
Bort62's Avatar
What Madmax said.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
