Oil Light
Old Jan 30, 2001 | 05:02 PM
85berlinetta's Avatar
Oil Light
My oil light started comming on when the engine hits around 4500 rpm. I checked the oil and there was enough. It has good oil pressure too. Any ideas? Hoping its not a cracked block. Or maby that is a good reason to get a 350!
p.s. it is an lg4
Old Jan 30, 2001 | 06:29 PM
Vader's Avatar
85,
I'd start looking at the sensor. If that is O.K., you might have some problems with sludge buildup in the case that is inhibiting oil drainback. The higher RPM requires more oil flow, and the pump might be starved for oil if the pan isn't staying full.
Later,
Vader
"Make Me Bad..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
