change from 1.5 to 1.6 rockers
Old Jan 30, 2001 | 02:30 AM
JPrevost's Avatar
Car: 91 Red Sled
Okay, lets say I were to get the 330hp 350. It was dynoed with a 650 cfm carb. I'll have the 670cfm holley TB with my TBI system and SLP headers - full 3". My question is what kind of performance if any would I recieve from changine the rockers from 1.5 to 1.6?
The cam is a modern dual pattern interpretation of the old '65 to '67 Corvette 327 cam. But with more lift and duration on the exhaust side, it does a better job of clearing exhaust from the combustion chamber. Also decreased duration and lift ever so slightly on the intake side to build more cylinder pressure.
CAMSHAFT: 24502476 Lift: .435" I, .460" E. Duration @ .050: 212 degrees I, 222 degrees E
So what do you guys think? Is it worth getting 1.6 rockers? Can I put the 1.6 on the intake only or what? Sugestions...should I just swap out the cam for a larger?
, Jon (91 RS too many mods to list), getting new engine in summer
Old Jan 30, 2001 | 05:36 PM
ede's Avatar
ede
i wouldn't get 1.6 rockers just for the sake of having them. if i were buying rockers i would, if i was building and engine i would. with a .5 lift cam and 1.5 rockers going to 1.6 will only raise it to around .54. yeah it's a gain, but i doubt you'll notice any big change.
ICON Motorsports
1st & 3rd
Old Jan 31, 2001 | 03:18 AM
JPrevost's Avatar
Car: 91 Red Sled
Okay, thanks for opinion and I understand but what about having the 1.6 on the intake side. Wouldn't that help the engine make higher rpm power? The 330hp vortec engine was dynoed with a 650cfm carb. I'm thinking the 670 Holley will want just a little more intake lift and duration.
What do you think?
Cameeeero
Sep 18, 2015 04:00 PM
Brendankup
Aug 30, 2015 01:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
IrocZ'85
Aug 17, 2015 06:24 PM
happyhapka
Aug 15, 2015 04:42 PM
