Initial timing .vs. ECM timing
Old Jan 31, 2001 | 10:13 AM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I've been looking at my spark tables and find the advance numbers to be quite high. In my case, they range from 20.0 to 40.1 degrees! Do these values represent the amount of advance provided by the ECM in addition to the initial timing? If you set your initial timing to, say 10*, that would result in over 50* of total spark advance! That doesn't sound right at all! I have been under the impression that total timing should max out in the low-to-mid 30's.
'87 IROC 5.7l TPI - original owner!
Old Jan 31, 2001 | 01:27 PM
Brent's Avatar
No. The ecm subtracts the factory initial (6degrees) from the total timing calculation.
More timing can be tolerated during light cruise situations.
theshackle
Sep 17, 2020 08:26 AM
89GTAOz
May 16, 2020 09:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
