Compression Test Procedures
Old Jan 31, 2001 | 01:28 PM
1989CamaroRs's Avatar
Im trying to determin if i have bad head gasket what measurements would indicate this on a compression test, btw this is on a jeep I6, not my camaro(thank god)
-Stock Tbi 305 with a lot of damn miles
-Edelbrock Z28 TES Headers
-3 inch Catco High Flow Cat
-3 inch Edelbrock Catback
-14x3 Summit Open Element Air Cleaner
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
79 Jeep Cj7
Old Jan 31, 2001 | 04:19 PM
ede's Avatar
ede
if it has a blown gasket you won't have a very high reading. what you want to look for is all the readings within 10% or so of each other. if a reading is way off you know you have problems.
ICON Motorsports
1st & 3rd
Old Jan 31, 2001 | 04:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You remove all the spark plugs; disconnect the power lead to the distributor; block the throttle wide open; and one at a time, hook the gauge up to each cylinder and spin the motor with the starter, allowing at least 4 compression strokes on each one. Like ede said, look for consistency between cylinders. It's hard to say what they "should" read, probably 160-180 would be typical. If one is low, or 2 next to each other are low, you have a problem. For that matter, there are problems that can make one cylinder much higher than the rest also, which indicates a problem.
ICON Motorsports
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
Magman
Sep 12, 2015 11:55 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
