True vortec intake?
Old Feb 7, 2004 | 06:35 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
True vortec intake?
Sorry if this doesnt fit, it has a little bit of everything included.
My friend just got rear ended in his silverado (5.7L). Hes selling me whatever i want from the engine. i already got the heads. My questions are these:
1.) could i somehow customize the intake to work? i have access to pretty much every part under the hood, injectors everything....i tool the intake apart and it looks alot like the crossfire design, but the ports look a bit larger.
2.) The thing is MAP so would it possible to program it to work with the 730 ecm? i know the fuel injection part is a bit different. but i could work around that. it has the hole for the distributor.
3.) would the 730 ecm (if it could be used) support the vortec fuel injection? or would i have to custom fabricate something?
im really not that concerned about performance...more or less that "custom" factor. help me speculate on this.....
Old Feb 7, 2004 | 08:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You will need the timing cover/gears if you plan on using this setup on you current engine. The manifold fits the heads all other components will transfer. You will need the ECM and the wiring harnes as well, yours will not work.. A couple people have swaped the full setup into thier 3rdgens and from what I understand they do quite well. You will need the fuel pump if yours will not support 55PSI. Ive been looking into a Vortec setup for my truck but havent had any luck yet.
Old Feb 7, 2004 | 09:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
How tunable is the ECM from the vortec?
Old Feb 7, 2004 | 10:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
From what I understand and have been told its very tunable but thats more of a question for the DIY prom guys. Persoanlly the stock tables for a Vortec 350 are plenty for my needs.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
