Car wont start!!!!!!
Old Feb 9, 2004 | 01:17 AM
IROC-Z5.7TPI's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Transmission: 700 R-4
Tried searching found losts of post but none with the same problem as me THE PROBLEM: I drove to the store today and the car ran fine, when i went out about an hour later and tried to crank the car up nothing, all the accessories are on and everything but nothing from the starter. So then I try to use a screw driver the see if the solinoid is messed up, it seems like the wheel on the started is spinning but not engagine the flywheel for some reason. Also tried banging the cr@p out of the starter to no avail. The starter is a Lifetime warrantied one and is only about a month old.
Any help is greatly appreciated.
Joey
Old Feb 9, 2004 | 04:52 AM
ede's Avatar
ede
check power to the starter, sounds like you have it, if so replace starter
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
