coolant hose question...
Old Feb 10, 2004 | 11:14 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
this is on a tpi engine... if i were to do away with the heat in my car, could i put a brass plug in the hole in the front of the intake manifold where there is a coolant passage for coolant to go through all the hoses to the heater core and back to the radiator.
basically thered be just two hoses to the engine, the upper and lower rad hoses and an overflow bottle.
Old Feb 10, 2004 | 11:20 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes sir block them all off. don't forget about the coolant that flows through the throttle body as well.
Old Feb 10, 2004 | 11:55 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
yeah i did the throttle body coolant bypass before...
excellent this should make for one clean engine bay...
thank you
Joe
sheachopper
Jul 31, 2019 11:27 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
