what do you think, c/r vs. flow
Old Feb 11, 2004 | 01:24 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
tell me what you guys think is more important, a higher compression ratio or flow#'s given all other variables being the same i.e. runner volume. say, if i compared two sets of similar heads, one flows 220cfm @ 28" and .500 and has a 10.5:1 compression ratio; the other flows 250cfm @ same and has a 9.7:1 c/r. which is going to be faster?
Old Feb 11, 2004 | 01:27 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i think the real question is which would make more power.. faster would involve way too many variables such as weight of the vehicle its in, trans and rear gearing, driver ability, elevation to name a few.. and thats a good question maybe someone will chime in
Old Feb 11, 2004 | 03:44 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Id have to say flow. A while back car craft did an article about how much power cr was really worth and they only got like 1 or 2 percent from a one point increase. The higher flow should be able to make up that 1 or 2 percent at the upper end so id have to say flow is more important.
Old Feb 11, 2004 | 09:19 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: what do you think, c/r vs. flow
Without a doubt at all, the better flowing heads have much more power potential.
Old Feb 11, 2004 | 09:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
For hp sake flow is what you want. For efficiency you want high compression ratios. If we could run gasoline engines at the same CR's as diesels they would be more efficient than any diesel ever made. They are currently working on a type of anti-knock devise that will allow up to 15:1 on pump gas without detonation. Their goal is 20:1. There is a little team here made up of automotive pioneers and ME grad sutdents here at school that say they know how and have tested it sucesfully on no other than a small block. However, they will not devulge anymore than that.
Old Feb 12, 2004 | 12:03 AM
cormyr's Avatar
Engine: 383 miniram
dankhound do you know what issue that article was in?
Old Feb 12, 2004 | 05:23 AM
3rdGenBlackBird's Avatar
Is that the article about someone stacking head gaskets to lower compression on the same motor?
Old Feb 12, 2004 | 06:09 AM
ede's Avatar
ede
i'd say flow=more power
Old Feb 12, 2004 | 06:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It depends on the rest of the combo. You can't generalize like that in an information vacuum.
However, with other parts surrounding them that are appropriate to them, the better-flowing heads will probably outrun the others. If you use the same cam, intake, headers, gear, etc., it's anybody's guess, because those things can easily eclipse the difference in those head specs.
Old Feb 12, 2004 | 11:24 AM
dankhound's Avatar
Car: 91 RS
Yep the artilcle was stacking gaskets on a mopar i think. It was a few years ago but like all magizines they recylcle some of the general tech stuff so i wouldnt be surprised to see something like that again.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
3.8TransAM
Sep 17, 2015 02:16 PM
