when to shift
Old Feb 11, 2004 | 03:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
when to shift
when u guys are drag racing, when do u usually shift, at the peak hp (4500) or do u climb up to redline 5500. or what?
Old Feb 11, 2004 | 03:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Probably a bit after the engines peak power in order to get you in your powerband in the next gear. Experiment a little and see what turns in the best et's/trapspeeds
Old Feb 11, 2004 | 03:53 PM
RiceKiller87's Avatar
Car: '87 IROC
Transmission: 700-R4
if ur goin to be driving that TBI RS,id try shifting at 4,000 RPM's 1 or 2 times...thats where ive shifted my TBI 4.3L S-10 and it seems a little faster than letting it rev to 4500 or 5000.
just try a few different areas until u find a good 1,start w/ 4,000...then maybe 4500,then 5000....just see what ur car likes best.
Old Feb 11, 2004 | 03:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok thanx will do. just was curious where other people shift at, and yer a good exmaple
Old Feb 11, 2004 | 04:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Most people (especially with near-stock motors) greatly over-rev their motors, which slows the car down slower than it would otherwise be capable of.
The ideal shift point is such that the engine is at its peak torque RPM immediately after it shifts. Go run your car on a chassis dyno, and believe what it says, even if you don't like that it shows that the engine has stopped producing power long before it reaches that colored marking on that trim package in your dash; if it says your peak torque is at 3200 RPM, then your shift points need to be such that it's at 3200 RPM after the shift. You may (almost certianly will in fact, with a 700) find that you need to shift at different RPMs in different gears; probably have to wind it up just a little further in 1st. You might find that you'll want to shift at 4300 out of first and 4100 out of 2nd for instance.
Old Feb 11, 2004 | 08:39 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
4000rpms-4500rpms
mostly I try to hit it at 4200rpms
mods have alot to do with it in(sig)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
