Question about max revolution
I have trans-am 91 with 5.0 lb9 engine and 5 speed transmission with 3.08 gear. The red line for the engine is 5000 rpm!! Is it enought? Can i shift at 5500 or this will be cause damage to the engine?
you should shift when the engine quits making power, or before valve float occurs.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
If it's all stock, there isn't much point in taking it much over 5000.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
MrJ, what ever happened that 'supposed peanut cammed car' line...
'89 Formula 305 TPI T-5
Check out my car HERE!
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Does a ported plenum count as a mod? I did that and my 305 TPI pulls really strong all the way upto 5500 rpm, although I usually shift at 5100 rpm. Before the plenum mod, 4500rpm was about the limit before it ran out of breath.
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Ported plenum
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
'88 IROC 305 TPI
Gutted airboxes
180 degree T-stat
Accel cap and rotor
Ported plenum
509 camaro fan
Sep 6, 2015 10:43 AM
