Re-installing Dist, but I don't remember how Dist. was alligned
Old Feb 13, 2004 | 10:42 PM
taman86's Avatar
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
I was replacing my intake manifold gasket on mt '86 TA 305 TPI, and I did not mark the distributor when I pulled it out.
I do remember how the base of the distibutor was setting, but I'm
not sure about the rotor? It was either pointing at the #6 wire, or the #1 wire. I think it was pointing at the #6 wire, so I'm goona try it and hope it works. Also I have not cranked the engine since I pulled it out.
Does any one have any advice on what to do at this point, other than just trying it?
Old Feb 13, 2004 | 11:00 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
DO NOT "just try it". That's the Ford way.
You need to find TDC on #1 by putting your finger of the spark plug hole and have someone tap the starter until you feel pressure.
Once you do, rotate the crank until the timing tab and balancer are at 0*. That will put the #1 piston at TDC.
After you get that, just point the rotor toward the #1 piston, making sure the oil pump drive shaft is lined up with the notch on the bottom of the dist.
Keep the hold down bolt just snug enough so you can rotate the dist a little as the engine first fires up to keep the car running, but not loose enough for it to move on it's own.
apo_bailon15
Mar 28, 2016 05:20 AM
fbirdroller
Sep 2, 2015 10:27 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
db057
Aug 22, 2015 08:17 PM
beast94
Aug 20, 2015 06:44 AM
