tires
Old Feb 4, 2001 | 12:44 AM
RedRS91's Avatar
tires
will 4th gen z28 tires (goodyear eagle F1s 245/50 16s fit on a third gen with 16in rims without rubbing or anything?
Old Feb 4, 2001 | 12:59 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Yes
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Feb 4, 2001 | 03:44 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Actually, 16 inch third gens were the 245/50R16. The fourth gen 16 inch tires were 245/45R16. So you'll be even better off.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 4, 2001 | 04:05 AM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
I think there's more to consider though. Wheel well depth is different, as far as I can tell, on different types of 3rd gen's, but I've never seen any kinda numbers on them. For example, I have a 91 Firebird with a 305 tbi with 215/65r15 (stock size, I believe) and my friend has a 89 iroc with 225/55r15 tires (I think that's right).. my tires rub, but his don't.
Old Feb 4, 2001 | 09:07 AM
Nitro Don's Avatar
a 245/50/16,no matter if its on a 3rd,4th,
vette,or anything else,is still a 245/50/16.
The thing that matters is the wheel offset on the rim.If it s a stock 3rd gen 16" rim you shouldnt have a problem.
Nitro Don
[This message has been edited by Nitro Don (edited February 04, 2001).]
Old Feb 4, 2001 | 10:44 PM
stingerssx's Avatar
Sorry Don, but I know for a fact that the fourth gens (at least the 16 inch) tires are all 45 series. Not 50.
Old Feb 4, 2001 | 11:00 PM
The ODB's Avatar
more than likely you have the factory plastic wheelwell inserts, so it doesn't really matter much if they do rub a little at full turn.
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305/383 with Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, 3.25:1 rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, .462/.470 lift @1.5:1 ratio. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Old Feb 5, 2001 | 02:12 AM
Dan87IROC-Z's Avatar
For some reason my right side front tire (falken ZIEX 245/50RZr16 tire) rubs when I turn the wheel at low speeds.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
