89 iroc z 5.7
Old Feb 5, 2001 | 03:57 PM
newtothegame's Avatar
89 iroc z 5.7
Could anyone let me know how I could tell the diffence between the 320 hp 89 iroc 5.7 and the 330 89 iroc 5.7? I'm having trouble trying to explain this to people.
Old Feb 5, 2001 | 04:37 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Don't know where you were getting those numbers, but they're way off. HP is either 230 or 240, difference being the dual catalytic converter setup, which is plainly visible if you look under the car.
Perhaps the 300s numbers you were thinking of were the torque numbers although you're still off. They were 330 and 345, again the higher rating going to the dual cat car.
The dual cat car also came w/ 3.27 gears instead of 2.77s, it is definitely the one to get...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Feb 5, 2001 | 06:06 PM
Mo's Avatar
Mo
i second that, could check the RPO codes too
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Feb 5, 2001 | 06:11 PM
Vader's Avatar
New,
Welcome aboard! (You might outgrow your user name quickly...)
There is some excellent base information on the models/years in the Tech Articles if you hunt it down. The details of the differences are listed for most years. If you have the lower-output 350, it's fairly easy to change to the higher output design. If you have the higher output design, it's also fairly easy to increase teh power and torque over what the GM Powertrain guys designed in...
Later,
Vader
"I know how to solve your problem, but I can't tell
you since you might use the information illegally...
Adobe Acrobat Reader 4.0
Cornholio7979
Sep 20, 2018 02:31 AM
z28addict8490
Sep 5, 2015 03:56 PM
pimprs
Aug 24, 2015 11:20 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
