Removing the runners from a tpi
Old Feb 5, 2001 | 09:53 PM
Stell1579's Avatar
on my 88 iroc, i cant seem to get the runners off. i got the bolts on th einside off, do i have to remove the fuel rails before taking off the runners?
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, 180 Thermostat+ Temp Switch, Relocated MAT, Cold Air. Soon to have Edelbrock TES Headers,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
Old Feb 5, 2001 | 10:12 PM
Guest
Guest
Posts: n/a
Heh... ok start counting
There are 6 lower and 4 upper bolts on each runner. Make sure they are all off. The plenum has to be off to get the runners off unless you wanna play magician and loosen the fuel rails. Some aftermarket runners and bases sorta change the playing field, but most of the time there are bolts hiding in there. My guess.... bottom 2 in the center of each pair of runners, both sides.
Old Feb 5, 2001 | 10:17 PM
Stell1579's Avatar
so i donot have to remove the rails, and there are a total of 12 bolts each side? what about the cold start injector on the drivers side. if so how do you remove that.
(i didnot start doing this yet, i tried over the summer when i changed the egr. i am planning to remove the entire intake in a few months so i am just testing the water)
thanks
-Stell
Vader's Avatar
Stell,
It's always been easier to me to remove the right set first. I think it's because there's a bit more space around the right side of the engine and no cold start valve. After the right set is removed, there is a bit more space to work around the left set.
The fuel rails do not necessarily have to be removed to get the runners off.
Later,
Vader
"I know how to solve your problem, but I can't tell
you since you might use the information illegally...
Adobe Acrobat Reader 4.0
Old Feb 5, 2001 | 10:19 PM
Vader's Avatar
Stell,
You've got mail...
Later,
Vader
Old Feb 5, 2001 | 10:21 PM
Guest
Guest
Posts: n/a
Theres 10 bolts each side. The cold start valve will just pull out of the runner when you get the bolt out. Dont be afraid to swing it up out of the way or bend the tubing running to it a little. If you want to do it "right" you loosen the nut on the back of the driver side rail where the cold start attaches and take it off before you mess with the runner. Bending is so much easier...
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
