Questions about Vortec engines
Old Feb 6, 2001 | 10:55 AM
R.O.B.'s Avatar
Just a courious question. The engines GM uses for the trucks, Vortec 350, what kind of engine is this. Is it the same as a normal 350, with Vortec heads, or is it an LT1 or LS6 type. I was just courious that if I went to the junkyard, and grabed one out of say a '98 chevy, would this be a 4-bolt main to use, with the added bonus of Vortec heads. Or is it a different monster?
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 6, 2001 | 11:08 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
this is an average sbc with vortec heads and a roller cam. It doesnt really matter if it has four bolt mains unless you plan on making 500HP or more at a high rpm. This is a rugged engine and will take some abuse.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Old Feb 6, 2001 | 11:14 AM
R.O.B.'s Avatar
Thanks, so then I assume its like the 87up third gen engines, 1 piece rear main seal, and roller cam. Thanks for your help.
Old Feb 6, 2001 | 12:13 PM
84TransAm's Avatar
I'd like to know what junkyard has new[er] vehicles! All the local ones have 80's cars.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
RPO codes point to Recaro version
Daily Driver, Flowmaster 80 Series
[This message has been edited by 84TransAm (edited February 06, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
