PCV question about blow by
Old Feb 16, 2004 | 02:59 PM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
On my 350 I can pull the vacume side of the PCV out of the valve cover and see a small steady stream of smoke or vapors coming out the hole in the valve cover. This is with the engine running. Is this normal, or is this blow by?
Old Feb 16, 2004 | 03:04 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
With the engine running put your finger over the vacuum hose. If your hose is pulling vacuum you should be ok. If you have excessive blow-by then your dipstick will blown out of it's hole all the time. Especially when you get on it hard. The steam, smoke, or vapors are probably normal. It seems to me that mine does that too. Probably cause it's hot.
Ghettobird52
Jul 5, 2024 11:18 PM
Victor6
Aug 30, 2015 02:09 AM
inferno15
Aug 29, 2015 01:48 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
