running rich: 2.8l v6 89 RS
Old Feb 18, 2004 | 03:29 PM
dcm01003's Avatar
Car: Black 89 Camaro RS w/t-tops
Engine: 2.8L (173ci) v6
my 89 v6 rs is running a bit rich...would a multispark MSD ignition system(i.e. 6A box and blaster coil) fix some of that problem...i want to get one anyway, but I was just wondering if it would help at all?
Dave M.
Old Feb 19, 2004 | 01:06 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The ignition upgrade wont change the rich condition at all. IF your rich enough to cause misfires the ignition box will reduce them some.
Old Feb 19, 2004 | 11:14 PM
tranamgta88's Avatar
running rich.....first thing id say is check timing, then check egr valve...when was the last tune up? mine is running rich too i believe, smells rich, and i get 12 mpg, and black smoke a 4000+ rpms....im pretty sure im running rich...OR just not burning the gas...i just checked my timing...its 5* advanced so i stuck it back to 0...seein if it changes anything, ill let you know....but the ehxuast didnt smell like it used to thats for sure
Old Feb 20, 2004 | 04:33 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Do the complete V6 Full Tune Up as described by TomP
https://www.thirdgen.org/techbb2/sho...hreadid=162251
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
BurlyChev
Aug 16, 2015 09:08 PM
gwade12
Aug 8, 2015 08:17 AM
