help - need timing setting
Old Feb 7, 2001 | 12:15 PM
speeddevil's Avatar
I'm missing the emission sticker off my car, can anyone tell me what the default timing setting is for a 1985 305 TPI (LB9) Trans Am?
Old Feb 7, 2001 | 12:25 PM
R.O.B.'s Avatar
I believe its 8*, yet 10* worked better in my car, flew through emissions too. Don't forget to unplug the distributor wire before setting your timing.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 7, 2001 | 12:56 PM
The ODB's Avatar
the 10 degrees initial would be great.
Old Feb 7, 2001 | 05:02 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Stock timing is 6*BTDC on an 85 TPI, but I have mine at 10* and it works great.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Feb 8, 2001 | 08:31 AM
speeddevil's Avatar
i set it to 8 and that seems to work great...thanks!
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
