Where can I find multitudes of technical information on autos??
Old Feb 5, 2001 | 02:42 AM
Dan87IROC-Z's Avatar
What web sites, books, and anything else other than this great site to find stuff on everything from setting up rear ends, trannys, engines, suspension, electrical, any of that stuff???
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 6, 2001 | 01:10 AM
BTTT
Old Feb 7, 2001 | 11:08 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Summit Racing has a couple of books, two of which are about the 82-92 Camaro. If you can find Haynes manuals at parts stores, I have the Haynes "GM Transmission Overhaul" book, and it gives a pic-by-pic rebuild of the TH-350/400/200-4R and 700r4. I'd imagine their "engine rebuilding" book is also just as good. (You can also find haynes online at http://www.haynes.com .)
For tech, nothing beats the GM Service Manuals from http://www.helminc.com - mine is in bad shape after using it so many times.. I'm thinking of buying a new one just for the heck of it.
Also, http://www.summitracing.com sells a video by Richmond on how to set up rear gears. I think they have some other videos, too.
http://www.eastwoodcompany.com sells books & videos on stuff like welding, bodywork, and suspension work.
As to web sites, have you seen the technical article section of this website? It's off the main page of thirdgen.org. Oh you can get free catalogs from Summit & Eastwood, by the way.
Oh- thought of one more spot. JC Whitney's (at http://www.jcwhitney.com ) also carries a bunch of books & videos. You can get a free catalog from them, too. In fact I think they also carry the Haynes manuals.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited February 07, 2001).]
Old Feb 8, 2001 | 01:38 AM
WOW, thanks a lot man!
Old Feb 8, 2001 | 12:02 PM
82z's Avatar
82z
When I wanted to learn more about cars and high performance I just decided to go to school and learn about it. I go to university of northwestern Ohio and study high performance. So far I have had classes in engine diagnosis and repair, a/c, automatics, and manuals. Soon enough I will be taking a class on high performance suspensions, fuels and ignitions, custom engine building and engine machining. This probably isn't the way you would want to go. I went to my local Borders book store and raided the transportation section. Authors to look for are John Baetchel, Ben Watson and David Vizard. Any of there books are excellent.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
eightsixseven
Dec 16, 2024 01:50 PM
bjpotter
Jan 22, 2019 12:27 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Reborn756
Sep 4, 2015 03:42 AM
