Help with Daily Driver...Engine ticking
Old Feb 8, 2001 | 07:28 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
I have a 95 Dodge Avenger with a 2.5L V6. At startup it sounds fine. After idling for 2-5 mins it begins to tick. It sounds like a lifter but it is overhead cam anddoesn't have lifters. Any ideas?? It goes away after the motor reaches 2000 RPMs or so. The severity of the tick lessened when I ran 89 octane gas in it. Anyone have any ideas?
Thanks,
Lars
Old Feb 8, 2001 | 11:53 AM
82z's Avatar
82z
Is it a valve type tick or internal engine noise? BTW ohc engines can still use lifters
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 8, 2001 | 12:01 PM
MrF-body's Avatar
they still had hydraulic lifters in that engine. don't think high octane gas would affect a lifter though. what weight oil is in it? does it change under load? sounds like it has an exhaust leak maybe? at the manifold or crossover pipe
have a beat to hell 87 GTA 305ci 700r4
t-tops,recaro,honeycomb wheels,digital dash
paid $600 at a junkyard for it (i had to save it)
Old Feb 8, 2001 | 02:07 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Sorry I am mistaken about the lifters, I thought it had cam followers. Any way. I thnk it has 10W30 or 5W30 synthetic (Quaker state). I'm not sure my other daily driver took a really big dump so I'm borrowing mom's other car. It is definately a Valve train tick, no doubt about that.
It goes away when the RPMs are above 2000. It doesn't matter if it is under load or not the tick goes away above 2000 RPMs. And it's definately not an exhaust leak. This is a real high pitched almost metal on metal tick.
I was just wondering if anyone had ny kind of experience with Mopar.
Thanks,
Lars
Old Feb 8, 2001 | 02:48 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
im not sure what it is, but my sister has the exact same car you described, and it makes the exact same noise, We've been trying to find it for about a year, but no one seems to know anything about it- including our Dodge dealer, go figure...
My 1986 Z28 and more!!
view my car (movie)
Fanatic1074
Oct 3, 2022 05:57 AM
meeklay812
Oct 1, 2015 03:46 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Vincent135
Sep 28, 2015 10:50 PM
david068513
South East Region
Sep 13, 2015 11:24 AM
