LT4 Hotcam info?
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
LT4 Hotcam info?
Who sells it and what are the numbers on it?
thanks.
1988 IROC-Z 350 TPI
(its an original 350 car)
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, Removed MAF Screens, bored .030 over, Other minor mods
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)
14.104@99.66
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
thanks.
1988 IROC-Z 350 TPI
Engine Mods:
Trans Mods:
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)14.104@99.66
www.mfba.org
Go to www.paceparts.com and look under performance parts. It will give you their price, along with the specs.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
I got mine from www.gmpartsdirect.com for $186 with shipping and tax.
The specs are:
Duration @ .050" 218*/228*
Lift w/ 1.5 RRs: .492"/.492"
Lift w/ 1.6 RRs: .525"/.525"
You will need to get new springs and you will have to have your valve guides shortened otherwise you may bend a push rod and f**k up a rocker arm. You'll also need a new timing chain set and a lot of gaskets.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
The specs are:
L98 TPI 350 (5.7L)
3rdgenparts
May 21, 2016 11:50 PM
Linson
Oct 1, 2015 09:50 PM
