Last Q, can I bead-blast my l98 heads? what about valves..
Old Feb 9, 2001 | 12:20 AM
Superblue87Formula's Avatar
I want to paint my heads while I'm rebuilding, it would be easy enough to bead blast them but would it damage them in any way? what about the valves?
btw, what size are l98 combustion chambers? what is comp with stock pistons? (I'm just full of questions tonight aren't I!!)
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Feb 9, 2001 | 01:03 AM
rhawki's Avatar
Bead blasting wouldn't hurt them in any way i can think of (off hand) as long as they're cast iron, aluminum would be another story. I'm assuming you're gonna have them hot tanked and replace the valve seals afterward though. They'll really need to be dipped cuz those frickin glass beads will get in every nook and cranny there, and you definatly don't want them coming out in the engine! You'd have to be careful around the valve seats too, unless your're also gonna have some type of seat work done afterward (3-angle or something)
I suppose you could tape off and seal up the "insides" with heavy plastic or something while you blast though, but again, if any glass beads slip by...
I think i'd just use oven cleaner (or paint stripper?) and re-spray them if you're not gonna re-work the heads.
-Rich
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
