Steering fluid leaking
Old Feb 22, 2004 | 06:21 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey my 82 and my dad's 90 is leaking power steering fluid. The 90 is leaking much worse, as it is now empty after a week and a half. Is their a common problem with these? Or a simple solution?
Old Feb 22, 2004 | 06:28 PM
YellowZ327's Avatar
Car: 1986 Camaro Z28
Engine: 1969 332ci
get some STP power steering fluid w/ the stop leak, i have a small hole in my pump, and it dont leak with the STP stuff in it
Old Feb 22, 2004 | 07:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Find the leak and repair it. Don't half-a$$ it.
Usually it's a line.
Take it ti the quarter car wash, clean it up, and see where it's coming from.
Old Feb 22, 2004 | 09:30 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
I've got the same problem. It's leaking, but my mechanic and I couldn't find it. we cleaned it off a few days ago, so now maybe we can trace the leak. Very true: clean the power steering area and then see what you've got. i'm suspecting that a seal in the steering sector might have gone bad, so when it expands/contracts it's leaking. do know for sure though, yet. it is a good idea to fix the problem rather than putting in stop leak. but i can't really say anything b/c i use the stop smoke in my oil b/c i can't afford to fix it right now.
Old Feb 23, 2004 | 12:32 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
It could be that the pump seal is leaking. Clean it up and check it. Also, if you replace it, do the whole unit w/reservoir. If you change just the pump and use the old reservoir they tend to leak again IMO. Pay the extra 10 bucks and get the pump with the reservoir. Just my 2 cents.
Old Feb 24, 2004 | 08:52 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Does power steering fluid harm an asphault driveway? I have been parking in one for about a month now and tomorrow I am going to take some fantastic and a towel to try to clean some of it up.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
