flywheel/starter question
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Are there any differences in the starters and flywheels on '85-'89 TPI autos? The reason I'm asking is the engine in my car was swapped out sometime before I got it and I need to get a new starter and I was looking into mini starters and I dont know which to get. The engine has centerbolt heads and no cold start injector so I'm pretty sure its a '89.
Thanks,
Matt
Thanks,
Matt
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
First, to clear things up. If you have an automatic, you have a flexplate, not a flywheel. Its either a 168 tooth or a 153 tooth (im not sure which, do a search). look at the application. Often times the starter will fit both the 153 and 168 tooth flexplates.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
This is what I have on both my 3rd gens. Nice unit. Fits both 153 and 168 tooth flexplate.
Weighs just over 10 pounds too.
http://www.tommyjohnsonjr.com/bs/index.htm
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
MOST after market mini starters fit both.... I'm not going to say all because im sure that someone would correct me on that..
Thanks for the replies. Anyone know when the number teeth on the flexplate changed? I cant find an answer.
On the flywheel/flexplate mixup
Thanks,
Matt
Thanks,
Matt
