Easy MAF question
Easy MAF question
When i disconnect my MAF do i need to disconnect the battery? I know it cant hurt but recently i heard someone say it is critcal to disconnect the batery when your futzing around with the MAF.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I would not disconnect it with the engine running or the ignition key in the on position, but it won't be neccessary to disconnect the battery. If you do it, will cause the ECM to reset. It will have to "re-learn" after a restart & possibly run crappy until it normalizes.
