Car runs like poo...
Old Feb 9, 2001 | 03:07 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Well, I put the stock ECU back in the car (I'd been trying to do the 7747 swap and chip burning) and a custom chip. It didn't fix the car, so I put the stock chip in it...did the same thing as the custom chip. It idles like a total turd. It's getting gas (you can see the injectors spraying), maybe a little on the rich side but nothing real serious. The #1 cylinder is getting spark when its supposed to (didn't have time to check the others it was getting late). My scanner only scans every now and again. The SES light is on when you turn the key to "on" and then goes off when the engine starts (I've been told this was normal). When the scanner scans there's no codes. It's got a serious miss that's causing the pooey idle (it misses through the whole RPM range). It'll only idle for about 15 seconds before it dies. I need to a list of things to check over the weekend...I'm gonna see if every cylinder is getting spark, what else do you recommend I check?
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Feb 9, 2001 | 03:14 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I would check the rotor and cap and make sure the spark plugs are all tight.
'89 Formula 383 TPI
Old Feb 9, 2001 | 04:14 PM
MrF-body's Avatar
check the coil. look to see if it is burnt thru (big white cirles on the sides) check the stator and the pick-up coil. if there is alot of rust on them try to clean it off. run it at night and see if any plug wires are arcing. a neat trick i learned too, is to spray the wires with a water bottle. it will show the arcing alot easier. also make sure there are no vacuum leaks
HE..HE....YOU SAID "POO"
have a beat to hell 87 GTA 305ci 700r4
t-tops,recaro,honeycomb wheels,digital dash
paid $600 at a junkyard for it (i had to save it)
[This message has been edited by MrF-body (edited February 09, 2001).]
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
