How much power did an 82 Vette 350 make?
Old Feb 10, 2001 | 01:30 AM
Dan87IROC-Z's Avatar
How much power did an 82 Vette 350 make? My friend got a 350 block, heads, and cam brand new from Checker. He put his 305 intake and exhaust on it because he couldn't afford to replace it at the time. So what kind of power numbers do you think he's lookin at?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 10, 2001 | 06:53 AM
Guest
Guest
Posts: n/a
What kind of intake is it? I seem to remember the word crossfire back then....
The power is going to be limited by the cam Checker used, and the intake manifold, whatever that is. They probably stuffed a peanut cam in there, so its making less than 220hp, probably more like 200.
Old Feb 10, 2001 | 08:36 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
The origional Crossfire injected 350 was rated at 200 HP.
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
sreZ28
Aug 14, 2015 07:48 PM
