bogs out??
Old Feb 24, 2004 | 07:29 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
bogs out??
ok i've been wokring on my car alot latley just got her 84 z28 with a 350 carb. but for some reason when i floor her she bogs down the started to sputer and then slowly picks up i let off on the gas about half way the pump her then it reves ever slow slowy i don't know why it would be doing that i know i'm running low on gas cause i've just been going around the block cause not insured and tabs are bad so yeah any help would be appricated
Old Feb 24, 2004 | 07:55 PM
daddy33's Avatar
Car: '85 Camaro
first thing i would is check your fuel filter. It should be located by your carb and takes 5 minutes to change. Mine did the same thing, i was always punching it and when i upshifted to 2nd gear it would only go to about 50mph then it bogged until i let off the gas. When i replaced the fuel filter and tested it out and went down the block and punched it. I was going around 75mph in 2nd gear then finally shifted to drive and keep going like a champ!
Old Feb 24, 2004 | 08:24 PM
Leahs88irocz's Avatar
Car: 1988 iroc-z baby! :o)
Transmission: soon 2 be replaced.
Leah says.....fuel pump or fuel filter.
Old Feb 24, 2004 | 08:31 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
thanx
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
