How much benefit from aluminuim drive shaft?
Old Feb 26, 2004 | 03:51 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
Just what the subject asks.
Note : I did a search, I would like someone to gimmie some details if they can.
Old Feb 26, 2004 | 04:49 AM
ede's Avatar
ede
less mass, less rotating weight
Old Feb 26, 2004 | 06:56 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Thats about it, also less vibration from the dr shaft.
Old Feb 26, 2004 | 07:03 AM
conlinj's Avatar
Make sure you get the 3" Ls1 shaft, better vibration dampning. Also it weighs 5lbs or so less then stock.
Old Feb 26, 2004 | 08:35 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'm not sure how many benefits I get from my factory aluminum driveshaft but it sure scares the crap outta me especially when I don't have a saftey loop
Old Feb 26, 2004 | 09:14 AM
92camaro's Avatar
We put an aluminuim drive shaft in a buddy's cars and it pick up about 1.5 mph in the 1/8 and we did not change anything else. It pick up some et but the track was not hooking good so we could only manage 1.71 60ft
Old Feb 26, 2004 | 06:06 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
what RPO code tells you that you have an aluminum driveshaft?
Old Feb 26, 2004 | 06:33 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I believe it was part of the 1LE option, it was also the factory replacement for vibration problems associated with the standard driveshaft and made its way into many cars that way.
Old Feb 26, 2004 | 06:56 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
someone told me if you had the G92 option, that it came with the same driveshaft as the 1LE had... there was an RPO code that dictated that, but i can't remember the darn code, lol
Old Feb 26, 2004 | 07:02 PM
Car: '89 IROC-Z
Ah I forget the code too but my car came straight from the factory with an aluminum driveshaft and its not a 1LE
Old Feb 26, 2004 | 07:28 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
JG1 is the aluminum driveshaft RPO.
Old Feb 26, 2004 | 11:13 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
interesting, 5lbs doesn't seem like it'd be to dramatic.
Old Feb 26, 2004 | 11:38 PM
3rdGenBlackBird's Avatar
5lbs is a lot for rotational mass.
Spin an empty soda can. Now spin an unopened full can. Notice the difference? Good, now open and enjoy your drink!
Old Feb 26, 2004 | 11:45 PM
MdFormula350's Avatar
every bit counts, plus the vibrations will go away verses stock steel crap.
Old Feb 27, 2004 | 11:37 AM
MNformula350's Avatar
i can say that's not the case, no flame just givin' ya info, my G92 Iroc has a steel shaft stock and no RPO for the aluminum one.
Old Feb 28, 2004 | 06:28 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have the G92... and it came thru with the steel one too.
I went from the steel to the aluminum and noticed a huge difference in absolutely nothing. Looks good though.
Old Feb 28, 2004 | 07:42 PM
DJP87Z28's Avatar
Thats about right, just a weigth saver and vibration stopper.
Old Feb 29, 2004 | 03:58 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
I've noticed a "vibration stoping" trend in the responses. But I don't notice an excess of vibration other than that which is a result of the stiff suspension. Maybe I'm crazy...
Old Mar 1, 2004 | 04:15 AM
Sometimes my stock steel driveshaft vibrates at speeds, sometimes it doesn't. Either way, it couldn't hurt get an aluminum shaft. It certainly won't HURT performance in any way.
Scott
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
