Replacing sbc cam bearings
Old Feb 10, 2001 | 10:35 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Just wondering if anybody has heard of a way to remove and replace cam bearings in a sb chevy without screwing them up. Mine are shot and right now I have no way to move the block to the machine shop for the $30 bearing R&R...thanks
Old Feb 10, 2001 | 10:46 PM
Guest
Guest
Posts: n/a
Borrow a tool?
Theres really no good way to get them in and lined up without experience AND a tool. If you still want to attempt it, use a piece of wood and find a way to cut it so that it fits exactly inside the middle of the bearing, and has a lip around that so you can hammer it in. You could use metal too, and cover that in rubber so you dont damage the bearing. I'll tell you now its extremely easy to screw them up, and they dont like to stay square with the block either. Being careful is the best suggestion I have if you do this yourself.
And also, do the back one first and work your way to the front.
[This message has been edited by madmax (edited February 10, 2001).]
Old Feb 10, 2001 | 10:50 PM
dhirocz's Avatar
I think I'll keep looking for a cam bearing tool...the shop doesn't have one and $135 isn't too attractive...I'll probably find a way to take the block to the machine shop. I'm still open to more ideas, though
Old Feb 10, 2001 | 10:57 PM
Guest
Guest
Posts: n/a
Plastic pipe.
Just thought of that, if you can get a size that just fits inside the holes in the block, that might work pretty good.
You will have to make sure its 90 at the end though.. if its off, the cam wont turn very well.
Old Feb 10, 2001 | 11:02 PM
dhirocz's Avatar
Good idea.
Tell you what. I'll go ahead and look for some pipe and remove the old bearings. If that goes well, I'll try reinstalling the old bearings(if they don't break) and installing the old cam to check rotational resistance. If that's OK, I'll install the new bearings. We'll see what happens tomorrow! Thanks for the idea, man!
Old Feb 11, 2001 | 01:10 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I would go the shop route. I remember reading that 1 of every 10 SBC have some serious core shift and you need different cam bearings in some of the saddles. 10% chance isn't much, but I'm no betting man on the basics in a buildup.
Old Feb 11, 2001 | 08:24 AM
ede's Avatar
ede
i made my istall tool. bought a set of bearings, measure them, turned a piece of steel in my lathe to size and use all thread, fender washers and a nut to "press" themn in with. you have 5 cam bearings in a sbc, they don't fit in randomily. guess i assumed you had a metal lathe in your garage, with out the lathe not sure how you'd do it.
ICON Motorsports
1st & 3rd
anesthes
Mar 10, 2016 10:35 PM
gta90
Sep 15, 2015 04:00 PM
red90IROCls1
Aug 25, 2015 06:56 AM
sreZ28
Aug 14, 2015 07:48 PM
Fronzizzle
Aug 9, 2015 01:15 PM
